@Zed Head thank you. For some reason, none of those forums came up when I was researching earlier. Sounds like that is what will need to be done. I found a website that said it had the new gears in stock (megazip) although I don't necessarily believe them. I reached out nonetheless. If it doesn't work out then I'll have to chance it with some used gears. Thank you!
Just saw this on Hybridz.  More expensive than a wrecking yard but cheaper than some places.  Has the ratio, apparently.
https://forums.hybridz.org/topic/133338-r200-370-open-and-z32-5-speed/#comment-1241777
@Zed Head You likely just saved the day. I can't thank you enough. Beats ebay vendors any day, I don't think MegaZip will find the gears, and the plus is he is located in Arizona. Waiting for my hybridZ account to be verified.
Glad to help, and good luck.  Hybridz is not very actively moderated.  Not sure how fast they move or what the rules are for messaging.  I can drop the guy a message and send him over here if you don't get through.
  • Who's Online   2 Members, 0 Anonymous, 1,280 Guests (See full list)
