I drew these in autocad. I printed them to pdf but they aren't to scale. They really need to be plotted to pdf to scale but I either can't or don't know how to do that. One DWG has a grid that makes it easier to adjust the pattern if necessary. One is without the grid for making pdfs
1971 240z jute patterns wo grid.dwg
1971 240z jute patterns.dwg
1971 jute floor mat.pdf
1971 jute tunnel pt1.pdf
1971 jute tunnel pt2.pdf
https://www.classiczcars.com/topic/68802-jute-patterns-tunnel-floor-mat/
The ideal situation would be to use the dwg's and find someone who could plot those for you. They are drawn full size. So they would plot 1:1.
I was hoping someone on the forum would have the ability to take the dwgs and export them to full size pdfs. Then you could print them from acrobat and tape them together for a template.
I don't have a driver that lets me select large sheet sizes for pdf's. If someone doesn't step up I can try to come up with a work around
  • Who's Online   1 Member, 0 Anonymous, 1,246 Guests (See full list)
