Captain Obvious Posted April 5, 2024 Share #13 Posted April 5, 2024 Speaking of hardware needed, Anyone know what hardware was used to attach the starter on the mid 70 cars? Here's a pic of what was holding the starter in, and I'm not sure either of them are correct. One has a "7" on the head, and the other has no marking. And there was no captive washers on either bolt. Here's what I took out: Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663656 Share on other sites More sharing options...
bluez Posted April 6, 2024 Share #14 Posted April 6, 2024 5 hours ago, Captain Obvious said: Speaking of hardware needed, Anyone know what hardware was used to attach the starter on the mid 70 cars? Here's a pic of what was holding the starter in, and I'm not sure either of them are correct. One has a "7" on the head, and the other has no marking. And there was no captive washers on either bolt. Here's what I took out: They look like the same bolts used on my 71. Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663681 Share on other sites More sharing options...
Captain Obvious Posted April 6, 2024 Share #15 Posted April 6, 2024 13 hours ago, bluez said: They look like the same bolts used on my 71. Thanks @bluez, but I got a follow up question... The two bolts that came off were different. Which one was like yours? The one with the 7 on the head? And did your car use any captive washers, or was everything loose? Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663714 Share on other sites More sharing options...
Zed Head Posted April 6, 2024 Share #16 Posted April 6, 2024 The carparts site is back up. It has some stuff. Looks like the parts taken out were half right. https://www.carpartsmanual.com/datsun/Z-1969-1978/electrical/starter-motor/for-manual/to-sep-75 Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663720 Share on other sites More sharing options...
bluez Posted April 6, 2024 Share #17 Posted April 6, 2024 3 hours ago, Captain Obvious said: Thanks @bluez, but I got a follow up question... The two bolts that came off were different. Which one was like yours? The one with the 7 on the head? And did your car use any captive washers, or was everything loose? Just looked both bolts had #7 flat and lock washers as well Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663725 Share on other sites More sharing options...
Captain Obvious Posted April 7, 2024 Share #18 Posted April 7, 2024 (edited) Thanks guys. So the parts manual says the two bolts should be different lengths. One of them is 35mm long and the other is 45mm long. And that makes sense... I just took a look at the starter and the two mounting ears are different thicknesses. The upper one is significantly thinner than the lower. I have the 35mm long bolt here, but I'm missing the 45mm long bolt. Anybody have old hardware lying around? BOLT-HEX M10X1.SX45 (M10 bolt, 45mm long, no captive washers and has a "7" on the head.) Edited April 7, 2024 by Captain Obvious Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663731 Share on other sites More sharing options...
bluez Posted April 7, 2024 Share #19 Posted April 7, 2024 Looks like eBay the Z connexion $7.80 https://www.ebay.com/itm/235480925042?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=235480925042&targetid=1645685074928&device=c&mktype=pla&googleloc=9003276&poi=&campaignid=20382335946&mkgroupid=149914365045&rlsatarget=pla-1645685074928&abcId=9316952&merchantid=6520324&gad_source=1&gbraid=0AAAAAD_QDh-0NNlyteFbSMSbnd2UsLOaK&gclid=EAIaIQobChMI0qiKgJivhQMVIEpHAR20AgsLEAQYASABEgJ9XPD_BwE Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663738 Share on other sites More sharing options...
Yarb Posted April 7, 2024 Share #20 Posted April 7, 2024 I recently bought the bolts from my Nissan dealer if you have a guy there that will work with you. Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663741 Share on other sites More sharing options...
Captain Obvious Posted April 8, 2024 Share #21 Posted April 8, 2024 Thanks guys. Those bolts on ebay are "close" and are "fit and function" correct, but not quite "form" correct though. I'm finding that much of the older hardware from the early cars is non-captive washers. Makes sense that as the car sales took off and production increased, Datsun quickly switched to easier to assemble hardware (with captive washers), but that's not the case for the early cars. I could certainly use newer style hardware. but I'd really like to have a bolt like what was originally used. No captive washers and no indent on the head. A little dirty, with patina, and unrestored would be a bonus. 1 Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663775 Share on other sites More sharing options...
Terrapin Z Posted April 8, 2024 Share #22 Posted April 8, 2024 On 4/6/2024 at 7:05 PM, Captain Obvious said: Anybody have old hardware lying around? BOLT-HEX M10X1.SX45 (M10 bolt, 45mm long, no captive washers and has a "7" on the head.) Odd, my M10 "7" bolts are all 1.25 thread, and my 1.5 thread bolts are all "9" bolts I'll look at some more, but so far it is the same on a big handful of bolts. Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663815 Share on other sites More sharing options...
Captain Obvious Posted April 9, 2024 Share #23 Posted April 9, 2024 @Terrapin Z I will double check the size and pitch of the bolts the next chance I get. Thanks, and I'll let you know! Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663856 Share on other sites More sharing options...
Av8ferg Posted April 9, 2024 Share #24 Posted April 9, 2024 Thanks guys. So the parts manual says the two bolts should be different lengths. One of them is 35mm long and the other is 45mm long. And that makes sense... I just took a look at the starter and the two mounting ears are different thicknesses. The upper one is significantly thinner than the lower. I have the 35mm long bolt here, but I'm missing the 45mm long bolt. Anybody have old hardware lying around? BOLT-HEX M10X1.SX45 (M10 bolt, 45mm long, no captive washers and has a "7" on the head.)Bruce, I think I have one. I had to replace mine yesterday because my new starter has a thicker flange. Link to comment https://www.classiczcars.com/topic/68877-hardware-needed/?page=2#findComment-663857 Share on other sites More sharing options...
