HS30-H Posted May 8, 2024 Share #157 Posted May 8, 2024 7 hours ago, Namerow said: Parts Manual shows that the PN changed as of Aug-1973. I wonder if this production date also marked the introduction of factory-installed air conditioning (as opposed to dealer-installed)? If hat was the case, the extra opening might have been added to provide a dedicated pass-through for AC-related lines and hoses. Factory-fitted air conditioning was available from the beginning of production in the Japanese market. The core support panel was shared between Domestic and Export markets, hence the mounting holes for the S20-specific air cleaner box and radiator overflow bottle being present on Export cars. 3 Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665156 Share on other sites More sharing options...
dspillman Posted May 10, 2024 Author Share #158 Posted May 10, 2024 (edited) It always makes me smile when taking off suspension peices that show the yellow Q/C brush marks….. Edited May 10, 2024 by dspillman 2 Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665290 Share on other sites More sharing options...
dspillman Posted May 10, 2024 Author Share #159 Posted May 10, 2024 Important prone to rust areas look very nice on drivers side, left hand side. Hammer and chiseled the thick coat of undercoating off these areas to confirm what lurked beneath the tar…… I know I have brought a few cars home with similar undercoating, that had possibly been applied to conceal the evil rust monster… Have mounted on rotessiere, waiting to have time to prime within a couple of days of blasting. 1 Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665295 Share on other sites More sharing options...
Patcon Posted May 10, 2024 Share #160 Posted May 10, 2024 The front frame rails look really good! Be careful blasting, the metal is thin and easily oil canned Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665297 Share on other sites More sharing options...
dspillman Posted May 10, 2024 Author Share #161 Posted May 10, 2024 45 minutes ago, Patcon said: The front frame rails look really good! Be careful blasting, the metal is thin and easily oil canned Not familiar with "Oil canned"? Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665298 Share on other sites More sharing options...
Patcon Posted May 10, 2024 Share #162 Posted May 10, 2024 If the metal gets too hot or overworked, it expands and becomes wavy. Basically ruined 1 1 Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665300 Share on other sites More sharing options...
dspillman Posted May 10, 2024 Author Share #163 Posted May 10, 2024 48 minutes ago, Patcon said: If the metal gets too hot or overworked, it expands and becomes wavy. Basically ruined Although I've only used the dustless blaster on a few cars, really haven't had that problem yet. the water is advertised to cut down on warpage due to heat.....I guess with aggressive media, metal could be moved around somewhat with a somewhat similar result.... Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665301 Share on other sites More sharing options...
Patcon Posted May 10, 2024 Share #164 Posted May 10, 2024 20 minutes ago, dspillman said: Although I've only used the dustless blaster on a few cars, really haven't had that problem yet. the water is advertised to cut down on warpage due to heat.....I guess with aggressive media, metal could be moved around somewhat with a somewhat similar result.... If you've done other cars with sheet metal this thin you should be fine. If you been doing American vintage cars, they are a lot thicker Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665303 Share on other sites More sharing options...
Patcon Posted May 10, 2024 Share #165 Posted May 10, 2024 Are you using a system like this? https://www.dustlessblasting.com/the-advantage Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665304 Share on other sites More sharing options...
dspillman Posted May 10, 2024 Author Share #166 Posted May 10, 2024 1 hour ago, Patcon said: Are you using a system like this? https://www.dustlessblasting.com/the-advantage Yes. I had a quote for cleaning my back porch, and 360’ of railing around the edges, and saw my chance to argue for the unit , in the name of buyingbthe machine for half the cost of the quote….. still haven't finished in the backyard yet, but is is convenient for ‘occasional body panel, car etc…… 1 Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665305 Share on other sites More sharing options...
Patcon Posted May 11, 2024 Share #167 Posted May 11, 2024 Good for you! 😉 Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665307 Share on other sites More sharing options...
dspillman Posted May 11, 2024 Author Share #168 Posted May 11, 2024 Cart in front of the horse syndrome…. Put the refurbished alternator is proper painted stator housing waiting on a home……. 1 Link to comment https://www.classiczcars.com/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?page=14#findComment-665308 Share on other sites More sharing options...
