Had one years ago. Switch mounted on the turn signal lever. Turned out to be a real mess. A lot of drilling and really ruined the look of the engine bay. Not to mention the model I had worked off the drive shaft and a lot of drilling into the body. I regret installing mine personally. It’s all been removed during the restoration. A lot of spot welds to fill holes.
Rostra seems to have the only commercial consumer cruise control system. Pic below of what I got recently from Amazon.
Just need a speed digital signal. There is a couple of options, you can splice a “thing” (I’ll find a link eventually) into your speedo cable, or if you have a GPS speedo, then do away with the cable all together and use this.
https://protunerz.com/collections/sensors/products/mechanical-to-electrical-vss-metric-with-connector
Now the hot tip is as Duffy says, go Drive by Wire and let your aftermarket ECU handle the cruise control duties. And idle control, etc. Its just a big step. There are actuators for triple carbs or throttle bodies too. See what efihardware in Australia  has. Cool stuff  https://www.efihardware.com/products/c598/dbw-components
I have seen a few folks working on nice solutions with 350Z throttle bodies and pedals, what are you doing Duffy?
Edited by zKars
No ECU. 71 240
JC Whitney, the good ole days, some the stuff in there was just so horrible. Good memories.
I figured there was a GPS sensor that could be included with some units, I'm just starting to the search.
Edited by DC871F
Quote
The downside to using GPS for speed is that you need a good solid signal. The more satellites received, the more accurate.
If you are in a wooded area, or an extremely cloudy day, the cruise might not work as well as intended.
  • Who's Online   2 Members, 1 Anonymous, 1,433 Guests (See full list)
