Guys, i am hitting another issue. The ZCarDepot do not have the retainer for the hatch lock cylinder. It is a bit thicker than the door ones. Is there some other source or alternate product? They do have a 240z door lock retainer which seems a bit thicker but I have not tried it.
Appreciate some help ...
Edited by MH77280Z
https://www.classiczcars.com/topic/68951-trunk-hatch-lock-retainer-280z/
  • MH77280Z changed the title to Trunk hatch lock retainer 280z
I had the same issue. I think the rear hatch retainer clip is unique to the hatch lock and is a bit bigger.
i ended up ordering this clip and taking a dremel tool and widening the gap to make it fit the lock. Its a bit on the small side, but it did work.
Crown Automotive-2583377 Lock... https://www.amazon.com/dp/B077Z8NKQ6?ref=ppx_pop_mob_ap_share
That one you linked to at ZCD is too small for the hatch lock. It is for the early Series One fuel door latch.
Apparently ZCD didn't offer one my bad ^^   I tried MSA and they list one but it is out of stock. (discontinued, same at Nissan)
I do have this one, as you can see it is the largest clip on the car. A little clean up needed.
Let me connect on pm
  • Who's Online   3 Members, 0 Anonymous, 1,354 Guests (See full list)
