I am getting close to being ready for tires. I have been looking at several options:
1. Kuhmo Ecsta PS31 215/55 R16 about $136
2. Continental Extreme contact DWS06 Plus 215/55 R16 about $151
3. Toyo R1R 225/50 R16 $181 (not available in the 215)
As the title says, I am going to be running Rota RB's 16x7 with a +4 offset
I am running Eibachs and am planning on an airdam up front. So no stock valence. I was thinking the 215's aught to clear the rear wheel arches.
I really like the Toyo's but I am not sure they will clear and I don't want to deal with scrubbing right now. I might roll the fenders eventually but no time for it now.
Questions:
Is anyone running the 215 on a similar setup? Does it clear?
Is the +4 enough to get the 225's to clear in the rear?
Any preference for which of these 3 people like and why?
Thanks, C
I did read some other threads but they were for other wheels and I decided to not muddy up those threads
Edited by Patcon
https://www.classiczcars.com/topic/69038-tires-for-rota-rb-16x7-4-offset/
Rota Grid 16x8 +10. I run 225/50 ZR16
(my fenders are rolled (as in: the inner flange with no pull, and as much as you can roll the rear inner flange as it gets pretty "thick" near the exterior...) I have coilovers and camber plates but I run the rears nearly flat)
Edited by cgsheen1
  • Thanks 1
Im running the rota rb 16x7 +4.
First I installed 225 50 16 (clears the original struts without any issue.)
But stones hit the lower body all the time. After a complete restauration i didn't like that.
Then i went 215 55 16 and no problem at all.
  • Thanks 1
  • Who's Online   1 Member, 0 Anonymous, 1,226 Guests (See full list)
