How much is too much - metal shavings in oil pan?
Sorry I missed some of the additional replies.
Lots of good questions being asked. I did not remove the valve cover. But still can I will do a bit more looking. The rebuild did not involve any milling. But there was some assembly work done with the valve cover off. This was done after the oil pan was on. I did check the bearings for slop and they all felt to be the same. I will post an update tomorrow.
Thanks to all
12 hours ago, crshowers said:
Grannyknot I am feeling pretty confident that you nailed my problem. I removed the bolt and the end of the bolt is worn down at an angle. The angle part is shiny. See 2nd pic.(2.5 mag.) Pic below shows the size of shavings compared to a dime. There were no shavings in the oil pump screen.
I also cut the oil filter open and found no shavings.
Do you think if I grind the bolt down by a 1/4" I will be good to go?
Don't guess, remove the valve cover, install that forward bolt holding the thermo housing on, make sure there is space between the end of the bolt and the back of the chain guide.
@Captain Obvious is right about the chain guide being steel, I'm mixing up BMW chain guides with Nissan guides. If the shavings you found in the pan are aluminum then they came from somewhere else and as mentioned above could have just been sitting in an oil passage and got blown out into the pan on first start up.
  • Who's Online   2 Members, 1 Anonymous, 1,452 Guests (See full list)
