6 hours ago, Captain Obvious said:
Sigh. You are correct. I accidentally referenced someone else's pic. That's two strikes for me on just this page alone.
Don't be so hard on yourself.. it's a common mistake..
(I remember i once sended someone his own carpart pictures when he asked for some pic's of parts of 240z's ! 🙈 ... sometimes you have them all mixed up and way to many pictures made..)
On 10/14/2024 at 8:04 PM, Patcon said:
Maybe you ended up with one half of each unit?
Possibly... but I don't see any evidence yet that there was a difference in the back plates from inception until 6/1972.  However...
I also only see one part number for the cover, and we know there were different versions of that from inception, but before the 73 models:
So, perhaps there are differences in the back plates also (before the 73 models).
Well after my botched measurement earlier on, hopefully I can regain some credibility.
Comparison pics of the 72 (orange) and the 1970 case. (purp)
One extra bracket on the back of the flat plate.
Lids look like they close well, orange has a filter, Purp does not.
They both look flat to me.
The filter holder went from 4 outside the filter spring clips to the inside the filter blockers
27 minutes ago, inline6 said:
Excellent!  However, I do believe your orange back plate should be paired with your purple cover.  And purple backplate with your orange cover.
You are correct sir, choke cable bracket.
This is a great discussion. I went out and had a closer look at my #957 car and found that it has the early air cleaner cover paired with the later backing plate with the choke cable bracket. There is always something new to learn.
This got me wondering about what was on my #6521 that is undergoing restoration. I pulled that air cleaner assembly out from my crawl space, and learned that it has fewer return air connection points. It was news to me but makes sense as #6521 is a Canadian market non-emissions car, that did not come with an air pump. I looked in the JDM parts book and it is the same as JDM assembly part number 16500-E4301 as shown below.
Here are a couple of the pictures that @Terrapin Z posted above, edited to add my early non-emissions air cleaner for comparison. My learning continues.
Edited by CanTechZ
  • 3 months later...
  • Who's Online   2 Members, 0 Anonymous, 1,077 Guests (See full list)
