Posted July 7, 200322 yr comment_43038 I need to replace all of the rubber hoses - well all of the rubber period. What is the best way to oreder these parts. I can order them one at a time.I thought if someone sold a kit, it would be a lot easier. Does anyone have any ideas? Thanks! Link to comment https://www.classiczcars.com/forums/topic/6913-rubber-and-hoses-replacement-question/ Share on other sites More sharing options...
July 7, 200322 yr comment_43047 You didn't mention which hoses, engine or fuel tank.However, if you check with Motorsport Auto or Victoria British you should be able to find some of them.One note, many of the hoses in the engine compartment can be purchased at your local Auto Parts Store.2¢ Link to comment https://www.classiczcars.com/forums/topic/6913-rubber-and-hoses-replacement-question/#findComment-43047 Share on other sites More sharing options...
July 7, 200322 yr comment_43048 And if it is the heater hoses, the only place I know of that sells them in a "kit" form would be Andy Russell. He has all the inlet and outlet hoses for the heater along with the supply lines on the passenger side of the engine, the Y pipe, 8 clamps and a heater control valve for 92 dollars.You can reach him at z@datsundude.com Link to comment https://www.classiczcars.com/forums/topic/6913-rubber-and-hoses-replacement-question/#findComment-43048 Share on other sites More sharing options...
July 7, 200322 yr comment_43056 Originally posted by EScanlon One note, many of the hoses in the engine compartment can be purchased at your local Auto Parts Store. I replaced my fuel overflow and heater / air hoses with rubber hoses purchased at the local parts store with no issues, I don't think pre bent ones would have been any easier. Suppose if you are keeping it original though. Link to comment https://www.classiczcars.com/forums/topic/6913-rubber-and-hoses-replacement-question/#findComment-43056 Share on other sites More sharing options...
July 21, 200321 yr comment_44647 the little fuel line that runs from the float bowl to the bottom of the jet, this line MUST BE FOR FUEL , do not use vacume line they are not compatable, the parts store fuel line is too stiff and will cause the choke to stick and bind. ZTherapy has the hose and also nissan. They cost $4.00 ea at Ztherapy . If you have a good hobby shop nearby you might try them as they may have fuel line that will work. :classic: Gary Link to comment https://www.classiczcars.com/forums/topic/6913-rubber-and-hoses-replacement-question/#findComment-44647 Share on other sites More sharing options...
