I just wanted to verify something before placing an order.  I'm needing these:  https://zcardepot.com/products/water-hose-nipple-intake-bypass-connector-oem-240z?_pos=68&_sid=780dca1dc&_ss=r
Per the description these are for numbers 19 and 22 in the diagram.  Would this also not be the same part for number 20 in the diagram?  Or is that a different one for some reason?
https://www.classiczcars.com/topic/69160-water-fittings/
The manifold I just took apart had a different fitting at location #20 but I don't think it would be a problem to use that same Zcardepot part in all three locations. The part I had was a straight tube, threaded on one end with two notches on the other end like a straight head screw would have.
I was planning to use the same nipple in all three locations. That was my plan at least.
https://www.classiczcars.com/topic/69160-water-fittings/#findComment-671530
  • Who's Online   0 Members, 0 Anonymous, 785 Guests (See full list)
