Good question. I asked Jim Frederick the same question because I have an early 71 also. He said if it’s got an early (monkey motion) transmission, it had D hubcaps. Mine has early transmission, angular half shafts, early ash tray etc.  No vents in the tailgate and no 240Z on the back roof vents, but if he’s correct, it came with D hubcaps. Anyone agree or disagree?
https://www.classiczcars.com/topic/69165-hls-30-hub-caps/#findComment-671617
Thanks for all the confusion guys!
Odd that they would change the hub caps in concert with the gearbox rather than at a specific production date, model year or VIN.   I guess I'll just take a chance and go with Z hub caps (sexier than the Ds).  Don't imagine it would make or break my chances if they ever featured 240s at Pebble Beach!
  • Haha 1
https://www.classiczcars.com/topic/69165-hls-30-hub-caps/#findComment-671721
My 04/71 build date 240 came with D hubcaps.  I always thought all '71 Datsun 240Zs came with the D caps and the Z caps were on later model years.  Unless I am misunderstanding the question....which seems to be happening more the older I get.
  • Haha 1
https://www.classiczcars.com/topic/69165-hls-30-hub-caps/#findComment-671724
  • 4 weeks later...
G'day All,
I'm still with hubcaps.  Can't find the 2 3/8 inch original hubcap centre logo, but I'll probably just make old ones look as shiny as I can.  So now I'm at the restoration of the hubcaps themselves.  I've had them chrome plated and have now masked off the areas not to be painted.  Expert advice from two sources in I'm to sand the to-be painted areas with 60 or 80 grit, then apply two-part epoxy.  Fine, but, but what colour,  it being a bit difficult to know what the original shade was.  After 53 years it looks like flat black, but could that just be faded original gloss?  Someone suggested charcoal.  Any experts here?
Many thanks
https://www.classiczcars.com/topic/69165-hls-30-hub-caps/#findComment-672330
EDIT: 60 grit sandpaper is too rough for anything on your Z. That's what painters call "floor paper". It's for sanding hardwood floors.
Here's the best I've seen with paint you can buy at a chain store. Many thanks @CanTechZ
Edited by siteunseen
https://www.classiczcars.com/topic/69165-hls-30-hub-caps/#findComment-672363
I wonder if "60 or 80 grit" was really meant as "360 or 280 grit"?  Those would be credible recommendations for paint prep.
https://www.classiczcars.com/topic/69165-hls-30-hub-caps/#findComment-672385
