It has been a while since we have posted anything under Oneway but finally getting back on our resurrection project.  The pinion bearings are marked 6202 which is a standard bearing, 15x35x11, but the ones being removed measure 15x35x12.  Not sure if such a bearing is still available or will we have to shim the bearings?  The grease was a bit old in the rack and just want to do a complete cleaning and relube.  Also that top seal may be an issue as well, but have not done any research on that one yet.  The other dilemna seems to be the u joints in the steering shaft from what I have read.  They move freely but the seals are beginning to crack and am sure the joints should be upgraded.  Any helpful suggestions will be appreciated.  Thanks, John-Lugoff SC.
https://www.classiczcars.com/topic/69219-78-280z-rack-and-pinion-rebuild/
Managed to locate the 15x35x12 bearings at 123BEARING.  They are actually the NSK brand which is marked on the originals.  I just hate to take apart the whole rack and pinion and not replace the bearings and seals.  Hard to believe this 280z is quickly approaching 50 years old and it was left sitting for the past  almost 20 years.  Registration tag on the car had a 1996 date.  The bearings and seal are NLA through Nissan.  Both are rather odd sizes.  Just about finished up on the floor pans, battery tray,other rusted out structures, and will begin the reassembly process as time permits.  Have a good day, John-Lugoff, SC.
  • Who's Online   0 Members, 0 Anonymous, 1,611 Guests (See full list)
