You would probably be just as well off to go ahead and buy a rebuilt pump if you want to keep it original. MSA has them for about 110 bucks, (with a 50 dollar core charge), which would be much simpler than trying to find parts to rebuild the one you have as I don't know that you would be able to find them. I've never seen rebuild kits or parts for them advertised anywhere so you might have to do a lot of work to rebuild it yourself.
It's either that or find a good used one.:ermm:
https://www.classiczcars.com/topic/6929-smog-pump/#findComment-43154
