texasz Posted July 10, 2003 Share #1 Posted July 10, 2003 What the heck is this!? How is this different than just having a valve job done? Link to comment https://www.classiczcars.com/topic/6951-three-way-valve-job/ Share on other sites More sharing options...
Bambikiller240 Posted July 10, 2003 Share #2 Posted July 10, 2003 Actually it's a 3 ANGLE Valve Job. What that means is that the sealing surface of the individual valves and their corresponding Valve Seats (in the head itself) are ground to 3 separate, different angle's instead of just one angle. This results in a better seal as the valves close. This keeps the power generated by combustion inside the cylinder where the power can be applied to the crankshaft (engine output power) instead of possibly leaking through the valve seats back to the intake manifold or to the exhaust manifold before the valves are opened via the camshaft, & rocker arms.HTH, Carl Link to comment https://www.classiczcars.com/topic/6951-three-way-valve-job/#findComment-43343 Share on other sites More sharing options...
texasz Posted July 10, 2003 Author Share #3 Posted July 10, 2003 Hmmm.... Sounds like a good thing to have done. How much difference does this make? I'm just wonding aoubt the cost for benefit to see if it's really worth doing. Link to comment https://www.classiczcars.com/topic/6951-three-way-valve-job/#findComment-43345 Share on other sites More sharing options...
Bambikiller240 Posted July 10, 2003 Share #4 Posted July 10, 2003 It makes a good bit of difference to the engine (I imagine) since that is what the factory manual specifys.Regarding cost, I don't know how much difference in price. I've never asked what would be charged for a single angle valve grind. I've always gone the the 3 Angle grind. Link to comment https://www.classiczcars.com/topic/6951-three-way-valve-job/#findComment-43352 Share on other sites More sharing options...
texasz Posted July 10, 2003 Author Share #5 Posted July 10, 2003 Is it obvious which has been done to look at the valves?I'm working a deal to get a head that has been rebuilt and never used and I'd be curious to know what was done to it.What should I expect to have to pay for the 3 angle job? Link to comment https://www.classiczcars.com/topic/6951-three-way-valve-job/#findComment-43355 Share on other sites More sharing options...
2ManyZs Posted July 10, 2003 Share #6 Posted July 10, 2003 Here's what it is supposed to look like when done properly. As far as a price tag, it is up to where you live and the going shop rates as much as it is who does the work. Link to comment https://www.classiczcars.com/topic/6951-three-way-valve-job/#findComment-43372 Share on other sites More sharing options...
