arman1969 Posted July 15, 2003 Share #1 Posted July 15, 2003 Does anyone know if the 5 speed trans is a borg-warner t-5? Will it fit L-24, L-26 or L-28 engines? Link to comment https://www.classiczcars.com/topic/7023-84-turbo-300z-5spd/ Share on other sites More sharing options...
Z Babe Posted July 15, 2003 Share #2 Posted July 15, 2003 The Borg-Warner T-5, 5-speed tranny is interchangeable in all "L" series. From what I have read, the 81-86 ZXT's also came stock with a Borg-Warner T-5, 5-speed tranny, with the 87-89 ZXT's and 90-96 Z32TT's having the Nissan tranny. However, I've been told that the Z31/"L" series tranny conversion would require some modifications -- for what reason, I don't know, or whether this is true. I'm sure that Carl could answer that one though. I've also read that the shifter in the T5 is not interchangeable, but someone told me that the '90's Mustang 5.0 stock shifter will fit it, and supposedly works much better, however, you might have to modify your console because the angle of 1st, 3rd & 5th gears is about 2" closer to the dash than the stock shifter. Here's some links if you would like more info. on the T5: http://www.zhome.com/ZCMnL/tech/AandBtranny.htm http://home.att.net/~jason510/tranny_ratios.htm http://www.geocities.com/zgarage2001/engine.html http://www.zccw.org/Tech/Tranny/07-97ZTransmissions.html Link to comment https://www.classiczcars.com/topic/7023-84-turbo-300z-5spd/#findComment-44075 Share on other sites More sharing options...
arman1969 Posted July 16, 2003 Author Share #3 Posted July 16, 2003 Thanks Zbabe for all the links, I really like the last one it has much of the info Im looking for. By the way, the picture of the blond bomb shell, is that how you look like? Link to comment https://www.classiczcars.com/topic/7023-84-turbo-300z-5spd/#findComment-44125 Share on other sites More sharing options...
Z Babe Posted July 16, 2003 Share #4 Posted July 16, 2003 You're welcome. And, yeah, that's a pic. of me. :classic: Link to comment https://www.classiczcars.com/topic/7023-84-turbo-300z-5spd/#findComment-44128 Share on other sites More sharing options...
