The bolts should be torqued to 17 1/2 to 19ft/lbs... and yes, they clutch pressure plate better be bottomed against the flywheel or you're going to have a vibration and a clutch that isn't going to last long.. make sure the pressure plate doesn't hang up on the dowel pins or any rust around the bottom of the dowel pins or you will deform the pressure plate housing.
