"Open", "closed" Isn't good terminology for SU's The chokes don't work that way. "Up" or "Down" could work better, but not clearly. Pulling the handle lowers the nozzle, a juicy pool of gas forms at the top of the lowered nozzle ready to be sucked up by a cold L motor.
Even with Mikunis, "open" would describe when the choke is engaged, as the choke "starting circuit" is open when you pull the handle and "closed" for normal operation.
But, "Close the chokes" is still accepted as engage the chokes. After all, the iconic symbol for choke is a butterfly valve closing a venturi. Looking down the throat of all my old American steel, it was easy to see if the chokes were closed.
https://www.classiczcars.com/topic/7251-choke-qs/#findComment-45618
Victor, you're right. I've learned alot about these SUs lately, and by pulling the cable you are pulling the nozzle jet down and this changes the fuel level at the bridge. And yep, the gas is richened for a cold start,and is slightly pooled at the bottom of the carb. You can't see this unless you have your air filter off, and carb apart. If you have someone pull the cable you can watch the linkage pull the nozzle jet down under the carb. No butterflys doing work here. Your throttle cable / pedal works the butterfly in the carb.
My Z has the choke cable removed (nozzle springs still there)smog, vaccum lines and anything else that is not required on the track. Not street driven, to bad, but sure looks better with all the garbage off.
https://www.classiczcars.com/topic/7251-choke-qs/#findComment-45640
  • Who's Online   3 Members, 0 Anonymous, 1,389 Guests (See full list)
