koreavet Posted July 31, 2003 Share #1 Posted July 31, 2003 Hello, I'm the second owner of an early (11/69) 240Z. The car came with a rearview mirror that is a little different from other 240Z mirrors I've seen. This mirror has a red dot on one edge of the day/night twist and nothing on the other edge. The broad sides of the twist have plain, vertical ridges. The other 240Z mirrors I've seen have a picture of a sun on one broad side and a star on the other side. I've attached a picture of my mirror. Is this a correct early 240Z mirror? Thanks. Koreavet Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/ Share on other sites More sharing options...
ZmeFly Posted August 3, 2003 Share #2 Posted August 3, 2003 or replacement from another car that would fit.its not original Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-45957 Share on other sites More sharing options...
Bambikiller240 Posted August 3, 2003 Share #3 Posted August 3, 2003 Originally posted by koreavet Hello,I've attached a picture of my mirror. Is this a correct early 240Z mirror? Can't tell if the mirror is original from the picture (too close of a view) but the twist knob is NOT original. As mentioned, it should have SUN on one side and STAR on the other side. Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-45961 Share on other sites More sharing options...
sjcurtis Posted August 3, 2003 Share #4 Posted August 3, 2003 koreavet, This mirror with the red spot could be the factory fit item for the 2000 GT GTR or a similar car, this item is multi fit and supplied to Nissan for at least four diffrent vehicle types. As you know in early production many things where in short supply a single mirror with a red dot could easily slip quality control if it arrived in a box of 1000.that one theorycheersSteve:classic: Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-45962 Share on other sites More sharing options...
ZSource Posted August 5, 2003 Share #5 Posted August 5, 2003 I checked out my 10/69 240Z (HLS30-00040), and it has the same red dot mirror as in your picture. I'd say that the mirror was unique to the 1969 production cars. Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-46120 Share on other sites More sharing options...
stevemasum Posted August 12, 2003 Share #6 Posted August 12, 2003 I've got 11/69, HLS30-00238, and that red dot knob is the same one on my car. A quick call to the original owner (I'm the second owner) confirms that the mirror was not switched out. The score:Original - 2 Not Original - 2Maybe - 1 Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-46878 Share on other sites More sharing options...
mdbrandy Posted August 12, 2003 Share #7 Posted August 12, 2003 My 11/69, HLS30-00215 has the sun/star, but since I'm the 4th owner, and the PO seems to have a faulty memory on many things, it isn't necessarily original. Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-46883 Share on other sites More sharing options...
26th-Z Posted August 12, 2003 Share #8 Posted August 12, 2003 I have 11/69 HLS30-00026 and have the sun star mirror. The red dot came with cars equipped with elephant oil caps! Seriously, you're fine. This is one of the technical peculiarities of our early series one cars. Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-46888 Share on other sites More sharing options...
projecteye Posted August 12, 2003 Share #9 Posted August 12, 2003 if you scratch off the red dot you could be one of a few lucky winners for the following prizes from Datsun's 1969/70 super sweepstakes......First Prize: two roundtrip tickets for you and a guest to the Woodstock Festival taking place in Saugerties, NY in August!Second Prize: A Duncan Butterfly Yo Yo and a set of real glass clik claks!Third Prize: a new rear view mirror to replace the old red dot mirror with an authentic 240Z Sun/Star from Nissan.go ahead and give it a try!!!! good luck!!!just kidding Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-46892 Share on other sites More sharing options...
kats Posted December 2, 2003 Share #10 Posted December 2, 2003 Hello, I checked my mirror,(03/70 made)it has star knob. But I looked at 2 owner's manuals,there is a different description in each one. #1 (15th Jan 1970 issued) "To rotate the adjustment knob,the red mark for day driving,turn the knob 180 degrees for night driving" #2 ( 20th Mar 1970 issued) "To rotate the adjustment knob,the "@"(star)mark for day driving,turn the knob 180 degrees for night driving" And please look at this carefully,this car is a very very early production 240Z,which showed up in the press kit 22nd Oct 1969 ,letter size brochure and canadian mono color brochure. I can see the red dot on the mirror knob. kats Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-59199 Share on other sites More sharing options...
kats Posted December 2, 2003 Share #11 Posted December 2, 2003 This photo is much clear kats Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-59201 Share on other sites More sharing options...
HS30-H Posted December 2, 2003 Share #12 Posted December 2, 2003 Some might not realise that there was yet another version of the earliest interior rear-view mirrors.This was from the 'no frills' base-level Fairlady Z ( S30-S ) and it had no knob on it at all - it had no 'Night' anti-dazzle position. This was also seen on the 432R, which shared many of the 'no frills' touches of the S30-S in an attempt to save weight. *96321-E4100 BACK MIRROR arse'Y - inside ( S30-S & PS30-SB ) ( no Anti-Dazzle position )*96321-E4600 BACK MIRROR arse'Y - inside *96321-E4601 BACK MIRROR arse'Y - insideI wonder if the E4600 is the "Red Dot" type and the E4601 is the "Sun & Star" type that very quickly superseded it? Alan T. Link to comment https://www.classiczcars.com/topic/7255-early-240z-rearview-mirror-is-this-correct/#findComment-59204 Share on other sites More sharing options...
