i have gotten a 74 260z the guy who had it before was in the process of changeing the flatops to roundtops and messes his back up he said he got the carbs new(Referb?) for $300, they never went on the car till i got it, and i can get it to run itll backfire threw the carb , and idle at 1500-2000 rpms i can get rid of the backfire and i now see that the front carb it leaking a little gas around the mixture nut, could the carbs have sat for too long?
they sat for about 7 months before i got the car.
https://www.classiczcars.com/topic/7287-carbs-sat-to-long/
Have you tuned them?
If they were kept in a plastic bad away from the elements everything should be OK. should still be new (or good working cond). You have to tune each crab separate. Get a MSA catalogue and buy a sync tool.
-Brandon
70
71 240Z
95 4X4 HB(DD)
https://www.classiczcars.com/topic/7287-carbs-sat-to-long/#findComment-45829
no they were let in the back of the car in a garage on the manifold, i got it to run with out backfireing now, cause i figured out which way "engages" the choke. now when i give it a little gas the idle shoots up to 2k from 1k and wont come down, i think this might be because im missing the rear carb throttle return spring :stupid:, i dont have a unisyc yet but my local parts place can get one for $24 now do i have to use the balace screw to get them in sync or the idle screws?
https://www.classiczcars.com/topic/7287-carbs-sat-to-long/#findComment-45838
If you have the money and time do them both.
If you depend on your Z every day do what you can the best you can.
Remember You only have to rebuild them once, then just keep them in good shape. They'll last forever.
You can buy original Nissan Rebuild kits off of e-bay. Maybe Nissan still carrie the pats.
https://www.classiczcars.com/topic/7287-carbs-sat-to-long/#findComment-46800
