Swapping in the BW T5 into my 71. There's two wires that hooked up to the stock transmission, but there's 2 pairs of wires coming off the T5 (driver and passenger sides). Which pair do I hook the wiring harness to? And what are these wires for? Thanks for any and all replies!
https://www.classiczcars.com/topic/7395-t5-conversion-wiring/
two wires out of the datsun box are for reverse light
check your t5 box put a multimeter on two wires should have no circuit when in other gears and should show a circuit when you put it into reverse then just connect your car wires to these two dosent matter which way they go
Mick
