Are you sure the pump is not getting power? The electric pump was installed by t he factory in the '73s to help withe the vapor lock problem. I am running just the electric pump on my Z and it works just fine. If your elect pump is shot, go to the bone yard and find a RX-7 that is carberated for sure not injected, and snag one of these . They work great and mine was only $15.00 . We even tried it on a tripple mikuni set up on a stroaker and it worked fine supplied all the fuel that was needed. Gary:classic:
Itook it off and put a battery to it and it worked,,, i know theres a fuse for it but is there anything eles that could stop it from working.. thanks..,
Yes, there is a internal fuel filter in the elec. pump. There will be a set screw on the side of the pump. get it loose then twist the cover counterclockwise it shoud pop off. Once that is off there will be a magnet then a gasket then the filter. :cheeky:
  • Who's Online   1 Member, 0 Anonymous, 1,423 Guests (See full list)
