I just got my fuel tank back from Moyer renu. They did a very nice job but wnen I looked inside I noticed a baffle between the shallow tank section and the large tank section. The supply to the fuel line is in the shallow section on the other side of the baffle. The baffle is about three inches high. I do not see any way for fuel to get to the supply line once the fuel gets below the baffle level. Once the fuel is exhausted in the shallow end there would be considerable fuel in the large end that would be left with no way of getting on the other end of the baffle. Could the material they used internal to the tank closed off any pasaageway. I hope you can understand this.
Confused
AL
https://www.classiczcars.com/topic/7568-fuel-tank-1971/
26thZ
I looked very carefully at the interface between the baffle and the tank . I see some puddling on the right and left side of the baffle at the lower curvature and suspect this might be the area for equalizing the gas level. The only way that I can think of checking this is by putting a fluid on one side of the baffle and seeing if it vents thru. An alternative would be to drill a hole at the lower end of the baffle.
Al
https://www.classiczcars.com/topic/7568-fuel-tank-1971/#findComment-47434
  • Who's Online   0 Members, 0 Anonymous, 1,485 Guests (See full list)
