I read this in an old post:
"Much better to set your timing using total advance of 32 Degrees BTDC with the vacuum advance off and plugged @ 2,500 RPM. So, no matter what the initial mechanical advance is setup for, you'll know you've got it right."
How is everyone setting their timing? I have a "Euro" distributor with single points D609-52 I think is the number on the side. When I set the timing at 17 BTDC (at 650 RPM as the workshop manual states), it runs fine but not as well as when I set it closer to something like 27 BTDC at the same RPM. Yeah, I know, that's a lot. And when I rev it while checking with a light it definitely is going past 36 degrees BTDC although at that angle, it is hard to read with the flat scale that is on the block.
Details: 77 L-28 shortblock - no mods
E88 head -not shaved with stock cam, stock Su's with SM needles
I run 89 octane gas.
Seems like setting it so that it just pings ever so faintly with full throttle in 4th gear from 30 to 40 mph works best for power.
Also, how are you reading 32 BTDC on 240's if you just have a pointer on the timing cover and 5 lines on the pulley? That only gives you 25 degrees, right?
Garrett
https://www.classiczcars.com/topic/7630-setting-240z-timing/
Timing is a funny thing. With the timing too advanced static you can have cold start problems and low speed problems, though yes it seems to give you the best power warmed up and running. Since your engine is mostly stock my recommendation is to do it how we did it in the old days, lug it like you are doing in 4th gear and keep reducing the timing until the pinging stops, pinging is bad. Now if you have problems cold starting or low speed continue backing it off until you have the best of both worlds.
One of the things to remember now that these cars are older is that the springs in the distributor are tired and the weights may be worn. This will change the curve of the distributor, the amount of advance to rpm. In a perfect world there is a perfect advance, giving you spark at the right time to make the most power at that particular rpm. When things get tired you get too much advance to soon causing pinging in the midrange until the engine rpm catch up to the spark advance. Remember that every ping is a little chunk blown out of the top of your piston, like I said not a good thing...
So by setting it so you don't have a ping through out the rpm range you know that you are not exceeding the advance curve no matter what your static setting is and hopefully getting the most power available from you advance curve.
Clear as mud right :)
Oh and to get higher timing marks, put a timing tape on your dampner and use the zero mark on the case as the reference point. I don't know any more who or if anyone has them anymore but once again that's how we did it in the old days :) It just divides the dampner into 360 degree marks using the TDC mark as the zero point.
Ah if it was just 30 years ago and I still had my 454 Monte Carlo SS I'd show you :) Boy am I glad I'm not buying gas for that today!
Lance's advice works. It's the same as my father instructed me 30 years ago.
Advance the timing untill it pings under acceleration, then retard it untill it will only ping if you bog the engine down in high gear.
I've been using this rule on cars where the scale just doesn't seem right. I have my Roadster club guys over from time to time for my help with tune ups. Every so often a car will pop up that WILL NOT RUN with normal timing adjustments, which leads me to believe something wasn't set up right during an engine re-build.
Using my Dad's formula for these "hard cases" has worked so far.
Garret, if your car isn't pinging like crazy with the total advance "well over" 35 degrees BDTC, I say the scale was funky.
Find you self a hill, advance the timing till it starts to ping, then retard it till it stops. Old fashion? Yep. Hard to track your adjustments? Yep. Works? Yep.
Thanks to both of you for the info. I just played with the timing for a couple of hours. Although seat of the paints is not scientific, there is enough of a difference between 17 BTDC and 32 BTDC to feel a difference. 32 BTDC or as best as I can currently read it, is where the pinging goes away in 4th with full throttle at 30 MPH. At this setting 6000 RPM comes a bit quicker in 1st, 2nd, and most noticeably, 3rd. Also at this setting, when I operate the throttle by hand with the timing light on it, I show something in the neighborhood of 45 degrees of total advance. Seems to be fully advanced around 3000. Also, I am not having any cold start problems.
That just seems bizarre to me. I checked TDC with a screwdriver in the number one spark plug hole and the marks on the pully are correct. I have the euro pully with just one groove. The mark furthest left when facing the car from the front is TDC. Each of the other marks (I'm assuming) is 5 degrees.
I wonder how many Z car owners are setting their timing by the book and missing out on a couple of HP?
Garrett
  • 1 month later...
  • 10 years later...
Initial timing really depends more on the advance curves of the distributor that is being used. If you have a reman. distributor with different weights, springs and vacuum advance canister than factory stock you probably wouldn't want to run factory initial timing. Just an observation that could be overlooked.
Being an old timer :-) Everything you've been told is correct. You can get as deep into advance curve theory as you desire but if you just want to have a good running car, retard the timing until it won't ping at anytime or perhaps barely when lugging the engine ridiculously low. It doesn't take many pings to break a piston ring in an old engine. (Hi-Lux PU, rarely pinged). I think you may want to put away the timing light. If you time it by ear you'll know it's right.
  • 2 years later...
I'm going to try and set my total timing today after finally getting the fuel levels right.  Does this sound right?
1. idle at 750 rpms
2. plug vacuum hose
3. set to 17 degrees
4. set light offset to 34 degrees
5. run it up to 3,000 rpms
6. adjust distributor until "0" pulley mark hits on light strobes
Thanks for any advice and my ZX distributor has 8.5 stamped on the weights.
EDIT, I have know idea what pinging sounds like so I'm using my high dollar light.
