My friend Charles has a post...... he can't post for himself for some technical reason (???) but here it is anyway.
Hello,
i have an l24 with an e31 head, mild cam, ported and polished, and a lightened and balanced flywheel. I am chasing an l28ET and if anyone wants something like mine.. high revs high compression then get in touch and we can sort something out! as i'm after an l28ET and obviously dont need the old one now!
Charles
https://www.classiczcars.com/topic/7743-wanted-l28et/
Even a crappy head design will flow heaps when "under pressure".
But more to the point, the P90 has a better chamber design than the N42, so ideally, use the P90. But a de-compressed N42 combo will still be able to produce 300HP with a correctly sized turbo & proper controls.
https://www.classiczcars.com/topic/7743-wanted-l28et/#findComment-48806
Damn, I wish that TSA had guidelines like that (defined).
If you plan on changing the engine in a car in SA, you need to apply in writing & then you are notified as to the yay/nay &/or engineering requirements.
Sammy if you do a search, I posted a few months back with the legal requirements that my car needs to satisfy in order to have an L28ET fitted to it.
The reason that it's 100% ok to modify a 240Z L24 with a turbo is that the car doesn't fall into the ADR27 regulation. Cars pre-ADR27 (in SA) can have unrestricted modifications to the engine, providing that they maintain the PCV system.
However, ADR-27 engines must maintain OEM cam, intake & emissions specs. ADR-27A engines must maintain OEM internals as well.
https://www.classiczcars.com/topic/7743-wanted-l28et/#findComment-48957
  • Who's Online   0 Members, 0 Anonymous, 1,466 Guests (See full list)
