Best sounding 240/280 exhaust
Thanks for the very informative page, although I think you misunderstood me--I did not state clearly enough. I meant I will probably remove all the plates and the endplate and everything and just run it open like my other car. You're right, just 'removing all the disks' (leaving the endplate) would no doubt create a bit too much backpressure. I'm dynoing Tuesday and might play around with the backpressure a bit. One of the main reasons I went 2.25 is so I could run it wide open. I think 2.25 is perfect for N/A Z motors (yes, save all your flames--I've read it all). I am guessing 18 plates would be very near wide-open in terms of amount of backpressure produced.
steve
Interesting that
I am running a lightly modified L24, mild cam, 6 into 1 header, triple webers and 280 distributor (nearly 180 at last dyno visit)
I have just moved from a MSA 2.5 inch "turbo" system (yes we get them in the UK) to a custom stainless 2.25 inch with a single "straight through" rear box and square tip -- I will bet on a buggers bum that my RWBHP has gone up, the car feels generally more torquey and pulls far better from low revs, I have also lost a misfire I had at around 5.5 - 6K.
Oh and the exhaust note has changed from a harsh wail to a more colourful deep "TVR" tone -- (not that you guys know what a TVR is) which is far less wearing on a 40 year old set of ears.
So in my very humble opinion I also feel that a 2.25 is better suited to a "street" L series
So in the immortal word of the human torch FLAME ON
Well people argue that 2.5" exhuast is perfect for a Z.... but here is my conclusion about my research on Z's...
For mainly stock or light modifications the 2.25" exhuast is ideal.
For modified or medium modifications the 2.5" exhuast is perfect.
For TURBO or highly modified Z's the 3" exhaust is even better.
Here is a baseline 240Z.... Dyno chart
1971 L24 stock bottom end, approx. 150K miles
E88 cylinder head, fresh valve job, shaved 0.025 inches. Otherwise stock.
MSD 6AL ignition, Pertronix Ignitor, MSD 8mm wires
Stock Rebuilt Distributor - stock advance curve.
Stock SU carb.'s, N-27 needles
This is how much more HP you get from Rebello or Nismo headers
*Almost nothing but a cool sound
This is for a 2.5" exhuast compared to a 3.0" exhuast
and finally.... an AIR CLEANER will actually improve your peak HP!
  • 1 year later...
steve
Hi Steve,
I have been doing some research on exhaust systems for my track car. I have a '71 than I am putting a stock '83 L28 into. Have had the intake ported and polished, but that about it, so far. This car will be used for NASA HPDE's, open track days, High Speed AX and still has to be civilized enough for the street (no trailer, have to drive to the track).
So far I have bought a Pacesetter Header with Jet Hot coating. My initial plan was to go with 2 1/2" pipes and end in a turbo muffler. Saw you post and found it intriguing about the tuneability of a Supertrapp.
Did you get to the dyno? I would love to hear your results. From the date of this post, you must have some experience with the system by now. What do you think of it?
Thanks,
Marty
Steve probably won't answere because he's long gone from this site. Mr. McConnell is over at 'West Coast Z Racer' which is a yahoo group site that I occaisionally browse. He's been gone from here since late '04. Couldn't take the crap here is more or less what he says.
  • Who's Online   1 Member, 0 Anonymous, 1,461 Guests (See full list)
