Chalking bumper rubbers
I've tried dozens of products over the years to use on old black bumper rubber.
The ONLY product that I found that would stop that chalking, was Clear Guard by Turtle Wax. Unfortunately, they no longer manufacture it. Sadly, this was also the best vinyl dash protectant. The problem with it, was that it did NOT require you to put a coat on EVERY week. My dash on my Acura has been 4-5 months since I applied it and it still looks good. No doubt they took it off the market due to it's long durability.
The only other method I've found, is to get a heavy duty scrub brush and scrub the heck out of them, then apply the best vinyl and rubber protectant you can find. You'll have to try various before you discover the one that won't make them shine and will also slow down the decomposition of the rubber.
The cause of this is that rubber tends to decompose after time, and even more so when exposed to the sun. Add to that that the rubber isn't being flexed, and that accelerates it even more.
HTH
Enrique
I have been doing a little research on this subject and buy a bunch of stuff from http://www.carcareonline.com/
EScanlon makes a good point about the rubber flexing. Rubber needs to flex or it will "dry rot". The chaulk you are talking about, Mark, is dry rot.
Turns out, silicon oil and formaldyhide are the two worst things you can put on rubber, or vinyl for that matter. Petrolium products will turn rubber to thick jelly. Most nationally advertised / marketed products contain at least silicon oil. Vinyl materials develop white spots because of silicon oil and rubber dries unevenly because of the stuff.
Go to this website - Car Care Specialties, Inc. - and read what this guy has to say. Do some web searches for "rubber restoration" and "vinyl restoration" and you will find similar discussions. A product called "Black Again" is very controversial and may be worth a try. Evidently, it is not the same formula as everyone loved years ago, but try 3M products, One Grand products, and Mequiar's products.
Take the rubber off. Clean it up real well with soap and water and soak it with something like "One Grand Exterior Rubber and Vinyl". While it is still dripping wet, put it in a ziplock bag and spray some more in the bag for good measure. Seal the bag up and let it sit for a week.
Let me know what you think.
I never use those silicone products like Armour All they are not good for vinyl and rubber, plus they leave everything to shiny, slippery and greasy.
I have used a product called Formula 2 made by PPC it will make your vinyl and rubber look BRAND NEW, and clean and condition it like nothing else I have seen. It's not greasy and it lasts a long time.
Speaking of bumper rubbers.
Does anyone know where to get new ones for a 73 240Z.
I tried removing them from the metal side pieces and broke off
a couple of the little embedded bolts. Not to mention that they
are pretty well scratched and scuffed.
How do you smooth out the scuffs?
Also, has anyone tried to replace the embedded bolts. Or any suggestions as to how to remount the rubber pieces without a few of the bolts.
  • Who's Online   0 Members, 0 Anonymous, 1,625 Guests (See full list)
