How do I wire a 5 prong relay to a fuel pump?
I need to wire a 5 prong bosch type relay to my aftermarket fuel pump. The relay is a 12V 30/40A
It looks like I should have:
1 wire to the +
1 wire to the -
1 wire to the fuel pump and
2 wires to the ignition
But what wire goes where?
The relay has a:
30
85
86
87
87a
What should I connect to what?
Thanks.
I dont have the data here at work but often there will be a small circuit diagram embossed on the side of the relay.
Basically you want your switch (ignition) to put power across the coil in the relay to allow your source (battery) to power the output (pump).
If that fails, run a search on relays as those numbers for the contacts are fairly universal.
For quick reference:
85 - is for your ground
86 - is from the switched source (ie: your ignition)
30 - is your power input (from alternator, battery, etc.)
87 - is your power output (in this case to your fuel pump)
87a - would not be used in this case
The 87a is the alternate power output. Relays are commonly used as a switching device. So the 87a output will power some other accessory when the main power is not switched to the 87 output. Did I make sense? Either way, it's not used in this case.
  • Who's Online   0 Members, 0 Anonymous, 1,608 Guests (See full list)
