help its smokin,,,
hey,
its now smoking pretty bad after i addes some mistre oil..in the enging.. i pulled the plugs and there all covered with oil..then theres oil coming out of the exahous.. flange gasket...what show i do? some one said that is lowered the viscasity of the oil now the oil is going through the valve seals...what should ido from here..flush out the oil...then what..will i need a vavle job..?
THANKS,
steve
Long live the Z...
https://www.classiczcars.com/topic/7849-help-its-smokin/
Originally posted by Victor Laury
Marvel Mystery Oil is "Top end lubricant" fuel additive, mainly for diesel engines. It's been 25 years since I've read the label but I don't remember anything about putting in your crankcase.
from the site
Description:
ADDED TO GASOLINE:
Cleans and lubricates fuel injectors and carburetors
Improves gasoline mileage
Reduces and prevents varnish and gum build-up
Extends spark plug life
Safe for catalytic converters and oxygen sensors
ADDED TO ENGINE OIL:
Prevents valve sticking and clatter
Fortifies properties of engine oil, prevents breakdown caused by extreme temperatures
Promotes easier cold weather starts
Reduces and prevents acid and sludge formation
FOR ALL MARINE ENGINES:
Inboard and outboard
https://www.classiczcars.com/topic/7849-help-its-smokin/#findComment-49367
  • Who's Online   0 Members, 0 Anonymous, 1,476 Guests (See full list)
