Generally, cheaper HVLP guns are used for priming, and the more expensive are used for finish paint. Most painters like to use a different gun for each color. So they use the cheaper one for primer since the primer gets a lot of workover anyway.
But do not think that a cheap gun could not be used for a decent finish spray. Some painters will tell you that some $99 HVLP guns are as good as a $500 gun. Of course full time, experienced painters could probably use a spray bomb and make it look good.
Look at this site:
http://www.lambolounge.com/
Read the Body and Paint sections. Very good comments to learn from.
Good Luck
https://www.classiczcars.com/topic/7920-spray-gun-advice/#findComment-49839
Just be aware that HVLP stands for High Volume Low Pressure.
Doesn't sound bad, until you consider that most good HVLP systems include their own air source. A standard home compressor won't be able to keep up with the gun.
Now, I don't have or use an HVLP, so I am not sure if the above is urban legend or fact. I still use the older style DeVilbiss and Binks guns. They're high pressure, but my compressor can keep up with them.
2¢
Enrique
https://www.classiczcars.com/topic/7920-spray-gun-advice/#findComment-49866
  • Who's Online   2 Members, 0 Anonymous, 1,059 Guests (See full list)
