Hey there,
Aussie here....
i had a quick search and didn't find anything specific about the mounts
I am wondering how to go about getting mounts made for the new engine, and how much i should be willing to spend on the mounts... Also aussies - what legal dramas are there with putting an RB20DET in?
https://www.classiczcars.com/topic/7981-rb-mounts-and-things-of-that-sort/
I went to the local Z specialists and they were fitting an Rb26 to a 240z, I asked about it and they said mounts are actually available off the shelf a store.
Im not 100% on which store, but castlemaine rod shop springs to mind.
I had a quick chat to cuong, and he's stopped making them!
Drunkenmaster - do you have any contact details for the people you spoke too.. Were they "240 rb26" mounts off the shelf:) or were they stock mounts for some other engine that just happened to work right:)
So does anyone out there know what i've got to do to make the sump fit?
And where i can find some mounts?
Also can anyone CONFIRM that you can't mount an rb20det onto the crossmembers themselves. as i'm told you can by a few people... confirm means you've tried and it didn't work.. not "i haven't heard that before":) (sorry)
Also, are the mountst he same for the whole RB series? meaning an rb26 mount fits an rb20 also? and even rb30?
thanks again guys, Charles
Charles,
To make the sump fit it's just a matter of cutting it 10mm below the bolting face all the way around, turning it around 180 deg & welding it back on. Do the welding while you have the sump flange bolted up as this will stop warpage. Next you have to cut the oil pick up & position it correctly for welding.
All RB engine mount brackets bolt up in the same spot in the block, the only differences are some are made of alloy & others made of steel. Go for the steel type, easier to cut & weld for the slight mods required.
Hope this is of some help.
Nick.
the 200zr (Jap only z31 with rb20det) has mounts / oil pan / oil pickup that will bolt onto a rb20 / rb25 (mods still needed for a rb26)
I have written down the nissan part numbers on this thread:
http://www.classiczcars.com/forums/showthread.php?s=&threadid=4098&perpage=15&highlight=200zr&pagenumber=3
