Since I'm not too familiar with the Zx engines I'll give you an idea at what you are trying to accomplish.
I believe the zx motors were around 8-8.5:1 stock. So you would probably be looking at a different set of pistons at the very least. You might need to shave the head a little (then shim the cam towers) to reach 10:1.
Try looking at the Datsun Garage in the links section for more info, I'm just giving you a guess.
10:1 would run OK on pump gas, as long as it's premium. I doubt you could use any grade less. Any more compression than 10:1 and you would likely have to use some sort of additive.
