OK, a REAL dumb question here..! How do I flick between high and low beam? (I'm serious!) The instrument stalk allows me to turn on park and main headlights but I can't move the stalk to flip between high/low beam. Can't see a floor switch, don't have an owner's manual, so I throw myself on your mercy for ridicule and enlightment! Help!
https://www.classiczcars.com/topic/8383-dip-headlights/
If your car is like the North American imported S30, you pull back on the TURN SIGNAL lever & the high beams come ON.............pull back again and the high beams go OFF
Not exactly the way it is done on modern cars.
OLD SCHOOL! :stupid:
**EDIT: PS can I drive your car?**
:D
https://www.classiczcars.com/topic/8383-dip-headlights/#findComment-53156
It is yet to go over the pits. Tried to take it out for some new tyres last week but the battery was flat so I charged it up. Then it rained for days and I couldn't bare the thought of it sitting outside. This morning, fine weather..battery too flat to crank it over again! Must have taken the edge off it with all my fiddling with headlights/taillights last night. Soooo, once again its charging up, tomorrow tyres, Friday over the pits. I'm going to treat the inspection as an exploratory exercise to see what needs doing but it should go close to passing. I think they might fail the windscreen which is nicely sandblasted an has a few chips - but inspectors seem to be more reasonable here than in Vic. I'll keep you posted.
To answer you question, I've been keeping driving to a minimum, quick trip to golf last Saturday and a brief cruise thru Subi later on...
https://www.classiczcars.com/topic/8383-dip-headlights/#findComment-53160
Sound like you need a new battery also.
My z battery cranked over my 260z engine about 20 different attempts, trying to get the thing started, jump started my honda a few times, and my brothers celica, then replaced my honda battery all together (as it died - would only hold a charge for a week), and i only charged it once.
https://www.classiczcars.com/topic/8383-dip-headlights/#findComment-53170
  • Who's Online   2 Members, 0 Anonymous, 1,538 Guests (See full list)
