EScanlon Posted November 6, 2003 Share #13 Posted November 6, 2003 To answer your original question:The 70 to 71 and for the most part the 72 Z's did NOT have intermittent wipers. If the combo switch you bought has a 4th detent for the wiper (Off, Int, Low, High) then that switch is for a 73+ Z with the ubiquitous late 72 mixed in there. That is why the connectors won't mate, there aren't enough wires in your existing harness to accomodate all the features of the new switch.Have you tried fixing the one you currently own? It is surprisingly easy, and as you pointed out, with the guys here, you'll get good advice quickly.Trying to jump the wiper motor or switch may seem easy but believe me it isn't easy to do.Disp: I don't know about the others, but I feel that the switch's seller's identity should be revealed. Not only did he refund your auction money, he refunded shipping?? That is exceptional. Knowing he's ethical is important for those of us who do shop on e-Bay on occasion.Enrique Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-56087 Share on other sites More sharing options...
Disposition Posted November 6, 2003 Author Share #14 Posted November 6, 2003 His EbaY username is "240z2go" . He believes now that the switch is actually for a '76 and will be re-listing it this week. The confusion was created when a friend of his suggested that the switch would work with any model 70-77. He is parting out his brother's Z for him, he doesn't know a lot about the car, but is very reasonable as explained earlier.Anyone interested in contacting him personally can PM me for his info.D Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-56090 Share on other sites More sharing options...
Daniel Posted November 6, 2003 Share #15 Posted November 6, 2003 Look at the excellent photo on the post called--indicator switch and the note I added. You will wish to check this also as the trouble may not be the headlight switch or That area could be the next problem.--While your there....... Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-56094 Share on other sites More sharing options...
cheney119 Posted September 20, 2009 Share #16 Posted September 20, 2009 I'd lay you odds it isn't the switch, I have fixed connections to repair my low beams and my right turn signal and they were both in the connection boxes at the passengers feet; really smart to put those connections down by your girlfriends feet. PLEASE CHECK THESE CONNECTIONS FIRST! Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-295266 Share on other sites More sharing options...
EScanlon Posted September 20, 2009 Share #17 Posted September 20, 2009 Doug;Thank you for your input, but the original poster of this thread - from October 2003 - may have already found an answer.It happens often, so don't feel bad if others tell you to check the dates of the post before responding.FWIWE Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-295267 Share on other sites More sharing options...
Arne Posted September 20, 2009 Share #18 Posted September 20, 2009 This may be a new record, you have revived an almost 6 year old thread! Of the original posters above, at least one is deceased (RIP, Carl) and only one of the rest still visits here at all!Please check the dates on the threads you read to make certain that a reply is appropriate.Edit: E, you were more polite than I was... Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-295268 Share on other sites More sharing options...
SteveJ Posted September 21, 2009 Share #19 Posted September 21, 2009 Oh come on, guys. Haven't you heard that Zombieland is about to hit the theaters. That MUST be the reason why all of these dead threads have been coming back to life lately. Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-295283 Share on other sites More sharing options...
DeesZ Posted September 21, 2009 Share #20 Posted September 21, 2009 On the bright side, the information may be pertinent to someone searching archives for switch problems. Consider it an 'added value' to a retired thread and the archive. Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-295317 Share on other sites More sharing options...
sblake01 Posted September 21, 2009 Share #21 Posted September 21, 2009 More importantly, if those connections are down by my girlfriends' feet, my wife needn't know that. Link to comment https://www.classiczcars.com/topic/8642-light-turn-signal-switch/?page=2#findComment-295319 Share on other sites More sharing options...
