I have a 1978 260Z (RHD) U.K. spec.
I need to know what model year it really is.
I was told that it is a '78 and the paper back to 1988 says its a '78 I'm just making certain what year it is.
it has the small bumpers and the 260Z body. L26 engine, dual su carbs
vin number
RS30-021332
I can get pictures for you if you need them.
for higher resolution click this
http://www.green260z.com/upload/DSC00226.jpg
fo rmore pictures
http://www.msnusers.com/Z-Cars/shoebox.msnw?albumlist=2
https://www.classiczcars.com/topic/8697-what-year-is-my-z-long/
My vote goes to a '78. Check the door VIN plate, it should have a manufacture date on it. I think the model years switched around Sept, so an 11/77 would be a '78 model. Looks in pretty good shape. BTW, the air damn belongs on a 240 with those marker light cutouts.
Originally posted by thebarracuda
no door plate,, looks like they took it off, and painted over the holes...
I've got the lights that go in the air dam, I just have to have the holes cut.
thanks
This is UK spec therefore I wouldn't expect door plate. The US is the only ones who got the door plate to my knowledge.
If you can post your engine number that may help member sjcurtis is collecting information on early S30 series Z's and may have an idea of what your car falls under in terms of chassis number and engine number may give a clearer idea of what year when compared with others.
Outside of the US the 260z ran till 78 and the larger bumpers were never introduced.
You don't have a vented bonnet something later cars were more notorious for especially in Australia.
Your interior trim may be a give away.
Early cars lacked things like a brake light in the heater cluster i have found that later cars had more options in the centre console areas especially in Australia.
I think UK and AUS cars are very close.
IF you can get a photo of your guages also it may help later cars used a different font for there guages they were fatter number and letters.
Early 74 cars were almost the same as late 240z's here.
That's my 2 cents for now.
