kings springs--anyone used them?
try measuring from the middle of the wheel(middle of the hub) to the edge of the guard(measuring straight up)..
this way it doesnt matter wot size of tyre you have and show how much lower the car is.
I'll go and measure mine(standard springs) when i put my guards back on.
Front: 335mm
Rear: 350mm
There isn't a 15mm difference in tire to guard gap front to rear though because I have 215's front and 225's rear.
It's roughly 1 inch from tire to guard front and rear....maybea tad larger gap rear.
Interestingly, a mate has exactly the same springs on his zed, but he has 60 profile tires, where I have 65's and his has a noticably larger gap as a result. Still looks good though. :)
Ok..on my two zeds, both of which are 260z 2+2's and both have their front guards off :cross-eye :cross-eye
So the REAR measurements are 420mm on no1 and 410mm for no2..
At 350mm it would look SO awesome!!
BUT maybe the guards sit higher on the 2+2???
mine mite be sitting a bit higher cos both cars have the spare wheel out/back seat/ most of the interior out and very very little fuel..
it is the measurement from the middle of the hub(in the middle between the nuts) ( LOL ) to the inside edge of the guard above it..(in the rear)
wot do you mean by non-trapping???????
Yep that's the measurement.
Non-trapping as in, when your suspension is fully extended, the spring is shorter than the distance between the plates that it sits between and can fall off onto the shoulder of the plate.
*Used the word plate cos I have no idea what the correct term is. :)
  • Who's Online   2 Members, 0 Anonymous, 1,387 Guests (See full list)
