Originally posted by jeffs73z
Would someone be able to tell me if the 71 Z lever is the same as the 73 or 72 lever?
Thanx in advance.
The "lever" may be the same BUT the WIRING that comes with the lever, and switch is not compatible. The wiring will not connect. There are significant differences to the wiring harnesses between the early Z's year by year.
https://www.classiczcars.com/topic/8818-turn-signal-lever/#findComment-56651
  • Who's Online   1 Member, 0 Anonymous, 766 Guests (See full list)
