Logical when you explain it as such.
However, wasn't the original concept to burn or re-route any emmision buildup back through the intake?
Is there a design that allows you to use the larger filters instead of the OEM aircleaner AND allows crankcase emmisions to be introduced back into the carburation system as originally designed?
In a word, YES :D
(as Dave said) In a word NO. :(
All of the aftermarket aircleaners that I have seen do not have such a provision. After having this filter on the valve cover for a while, you do need to clean it to remove any oil build up or it will eventually drip out on the engine.
  • 3 weeks later...
  • Who's Online   2 Members, 0 Anonymous, 1,262 Guests (See full list)
