Don't know about the ZX, but the 280 radiator will work. It will hang below the radiator support a few inches though as the core is taller. You will also need a different bottom hose IIRC.....
The 280 rad will have the whole bottom tank hanging below the radiator support, so if you have a stock valence it will show, if you have an airdam it will hardly be noticeable.
https://www.classiczcars.com/topic/9038-radiator-swap/#findComment-58307
The only bad news is the 280Z stock replacement radiator is a 2 row... just a larger core.
FWIW, Motorsport Auto's 3 row radiator isn't much more expensive than most of the original replacements you will find. They also have a 4 row but that is getting into the expensive radiators.
You can also use a Chevy style aluminum radiator from someone like Jegs or Summit Racing, you just need to find the one with the closest measurements....:ermm:
https://www.classiczcars.com/topic/9038-radiator-swap/#findComment-58334
Oops, I totally forgot the A/C equipped cars had a 3 row, but as to which year they started installing the 3 rows, I'm not sure, perhaps in late 74? I had a 73 with A/C many years ago and it had only a 2 row.
3 row is better than a 2 row, but, since you live in the southwest, it might not be a bad idea to spend the extra and get a 4 row, especially if you plan on using A/C....Better to spend a little extra on a radiator than to replace a warped head if it overheats.
https://www.classiczcars.com/topic/9038-radiator-swap/#findComment-58380
I did have a small problem when sitting in traffic this summer, but just added a bottle of redline water wetter to the system and it worked great! No more overheating, even in 110 degree heat!
It looks like I have all sorts of options for the new radiator, thx!
But I do think it I would like to get a front spoiler to "hide" the larger radiator, know of a good used one anywhere? ( I'll ask in the wanted section)
https://www.classiczcars.com/topic/9038-radiator-swap/#findComment-58473
  • Who's Online   2 Members, 0 Anonymous, 1,535 Guests (See full list)
