Hi
I was wondering if anyone could help me with this tacho problem.
Its a std tacho on my 240z, It was working fine for ages and now when I start the car it only seems to be reading about half the amount of revs the car is doing. Sometimes after a while it will all of a sudden start working correctly but then when I turn of the car and re start it is inacurrate again.
any clues?
I have another tacho so I am probably going to change it to see if I have just got a dead tacho, just thought I would ask to see first
thanks
Ash
https://www.classiczcars.com/topic/9055-240z-tacho-problem/
Most likely it's not dead, just in need of some t.l.c.
If you pull it, look for any loose connections both internal and external, most of the time the vibration from your Z will cause things to come loose
and the starting of the car can make the connection work and the next time the connection will jiggle loose,
something to think about b-4 you jump the gun.:classic:
Dave
https://www.classiczcars.com/topic/9055-240z-tacho-problem/#findComment-58411
