I am trying to install a petronix unit in my Z, but am having a bit of trouble. I think I have most of it installed properly, but I can't figure out where the wiring passes trough the dist. cap. The instructions say that there is no modification of the dist. neccessary... Can you tell me what I'm missing?
thanks
Matt
https://www.classiczcars.com/topic/9059-petronix/
That's what I was afraid of. Does the dist. have to be removed to do it. When I was trying to figure this out I was looking at that and I don't think I can get to it without removing the dist. That little cylinder shaped piece is the compressor? So I just take everything in the back there off, put the wires through and the little rubber grommet should fit?
Thanks for all the help guys
https://www.classiczcars.com/topic/9059-petronix/#findComment-58528
That cylinder is the condenser , and YES, you can easily remove the distributor by loosening the two bolts that hold it to the timing cover. Just make sure that you have the engine at Top Dead Center (shown in the picture), and the pull the Distrubutor out. Don't rotate the engine while the distributor is not installed. Do your work and re-install it with the rotor oriented in EXACTLY the same direction. Make your wiring connections, "Time" the engine and your done.
https://www.classiczcars.com/topic/9059-petronix/#findComment-58529
I just wanted to add that the dizzy can be removed in any engine position. It will only go back on one way...that is in time with the motor. Now if you dissasemble it completely, have too many beers and cannont remember the orintation of the dist cam...then you could have problems...LOL
https://www.classiczcars.com/topic/9059-petronix/#findComment-58567
  • Who's Online   1 Member, 0 Anonymous, 1,557 Guests (See full list)
