Masashi Posted November 29, 2003 Share #1 Posted November 29, 2003 Hi, I am Masashi Japanese who living in Las Vegas NV.Now I am trying to reduce smog (CO, HC) and take air pump and otherexust recycling system.If anybody has good idea for reduce smog, please let me know.Regards. Link to comment https://www.classiczcars.com/topic/9119-smog-buster/ Share on other sites More sharing options...
Ed Posted November 30, 2003 Share #2 Posted November 30, 2003 You could also install a Catalictic Converter on your exhaust. First you should check with your state's smog requirements. In some states a 30 year old vehicle is smog exempt.Or did I missunderstand you and you are trying to reduce / remove smog equipment currently on your car? Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-58857 Share on other sites More sharing options...
Masashi Posted November 30, 2003 Author Share #3 Posted November 30, 2003 Thank you for your advice.Yes, you are right. Now I am tring to take off all air pollution cotrol system ( air pump,vacuum control valve,check valve and anti backfire). My car is 71' made 72'model 240Z but in Japanese standard there is not those parts. When I was in Canada I had 74' 260Z but this car also all took off.In Nevada before 67'car only not necessary for smog check.As you said if I can't reduce pollution by my method, I need to put cataliser on middle of muffler. Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-58917 Share on other sites More sharing options...
Ed Posted December 1, 2003 Share #4 Posted December 1, 2003 On my 73 with 72 carbs I removed everything that had to do with smog. I did leave the PCV valve and the hose that goes from the top of the valve cover to the air intake. Go to the Gallery and check out some of the other members rides. You can get a pretty good idea of what you can get rid of. Most of it probably doesn't work anyway. Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-58963 Share on other sites More sharing options...
Masashi Posted December 1, 2003 Author Share #5 Posted December 1, 2003 Ed, where can I see your engine in your gallery?Also if you know somebody's engine is good suggestionfor my case, please let me know.I really appreciated your advice anyway. Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59016 Share on other sites More sharing options...
MariaAZ Posted December 3, 2003 Share #6 Posted December 3, 2003 Like Nevada, Arizona requires all cars built '67 & later to pass emissions.Our "new" 260Z failed emissions, which really came as no surprise. Has anyone modified the air pollution control system on a 260 & still got it to pass emissions? I am in the market for round top carbs to replace the flat tops, but am concerned about what to do with all the hoses, etc if I replace the carbs & breather cover.thanks in advance! Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59363 Share on other sites More sharing options...
owenk Posted December 3, 2003 Share #7 Posted December 3, 2003 Wait a minute, you mean to tell me that Nevada (anything goes state) and Arizona (republican strong hold in the west) has more strict emissions requirements than California (liberal stronghold in the west) ???:stupid: Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59370 Share on other sites More sharing options...
Ed Posted December 3, 2003 Share #8 Posted December 3, 2003 Originally posted by Masashi Ed, where can I see your engine in your gallery? Sorry, My engine is in pieces right now (It's getting rebuilt). I basically removed what I could since I didn't have to worry about emissions back in California.Question, how often do you have to take an emissions test, every year? Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59411 Share on other sites More sharing options...
MariaAZ Posted December 4, 2003 Share #9 Posted December 4, 2003 Arizona requires testing every two years for cars built after 1966. The older cars only have to pass HC & CO gas tests versus the "full monte" that younger cars are subject to. Still, doesn't matter; when you fail, you fail Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59421 Share on other sites More sharing options...
Masashi Posted December 4, 2003 Author Share #10 Posted December 4, 2003 Thank you for advice you guys.I made it! I took air pump and EGRthen over hall carb. change point andadjust fire timing then change spark plugto NGK BPR7ES-11.Then adjust bottom of each SU so finaly I couldpass emission test.result was HC =439 CO=1.84% (700rpm)For 260Z carb is flat top type but this carb isquite tough to adjust.Anyway I recomend take air pump and EGR.I have extra SU twin carb round shape but this is forroadstar SP (1500cc) not suite for 260Z.MariaAZ should change carb to 240Z type.Better ask Ms.Chroe in West Z whether they have used. Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59423 Share on other sites More sharing options...
MariaAZ Posted December 4, 2003 Share #11 Posted December 4, 2003 The round tops will have to wait; I'll have to deal with the flat tops for now. Is it possible to remove the EGR valve with the flat tops? I have a laundry list of things to repair/replace, and the EGR is one of them. Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59451 Share on other sites More sharing options...
2ManyZs Posted December 4, 2003 Share #12 Posted December 4, 2003 Maria,you could remove the EGR, but it would be better to replace it with a new one, otherwise, I doubt you will ever get it to pass.If the engine is in proper tune, you should be able to get it to pass without too much trouble. But, you'll have to make sure everything is in working order (smog pump, EGR etc...), the carbs are tuned correctly and the ignition system is in top condition as well. If the HC levels are a bit too high, you could always try leaning out the carbs a bit just for the test. You could also try an electronic ignition or an upgraded ignition if the car already has electronic ignition. Link to comment https://www.classiczcars.com/topic/9119-smog-buster/#findComment-59456 Share on other sites More sharing options...
