If MSA has it, you should try Chloe at MidwestZ, as she can probably get it also and give you a better price since she is one of our sponsors.
The one you want is the inlet hose, which is the one to the air cleaner base.
I'm just guesssing, but I think one end is possibly 1/2 while the other end is either 1/2 or 5/8...... been a while since I even had a car with a smog pump still attached....:ermm:
If at all possible, you probably will want to use the original if you can, as it does have some twist and turns in it that would make it hard to replace with a standard hose.
https://www.classiczcars.com/topic/9152-hose-size-needed/#findComment-59241
  • Who's Online   2 Members, 0 Anonymous, 1,256 Guests (See full list)
