feedback from some references:
"I'm running 3 x 40PHH-S with 32mm chokes on a Harada inlet manifold, Option 76 Degree cam, larger valves, raised compression and some porting of the ( E88 ) head. Exhaust system starts at an Option manifold running into a full stainless twin-pipe up and over layout. On my current setup the Main Jets are 160s and the Air Corrector / Main Air Bleed are 210s. All other settings and sizes are stock for the 'S' model 40PHH"
The stock 44PHH Mikuni jetting for the L-series sixes ( as recommended by Nissan's tech staff ) sold as Sports Option parts was as follows:
MAIN VENTURI = 37mm
MAIN JET = 160
AIR CORRECTOR JET = 180
PILOT JET = 55
EMULSION TUBE ( "JET BLOCK" ) = 8
f your Emulsion Tubes are marked "OA" or "OB" on top then you would be well advised to seek out a set of six "8" types and install them instead. This will be a great help with driveability and part-throttle response. The OA and OB are best left to racers, and are not as good as the 8 for the street.
the Nismo kit (16010-E4620) defaults:
Main Jet 175
Air Jet 250
Pilot Jet 55
Venturi 37
Jet Block -??
the factory Mikuni America defaults for the L24/26/28
Main 150
Air Jet 200
Pilot Jet 57.5
Venturi 34
Jet Block OA
pump jet 40
https://www.classiczcars.com/topic/9173-sample-triple-mikuni-jettings/
"The engine I have in car now is a L28 completely stock. ..
I am using the 44's and an electric fuel pump as fitted to the 73 and 74 USA Z. Mine is a 72."
Choke Tube: 34mm
Jet Block: OA
Air Jet: 180
Fuel Jet: 140
Pilot Jet: 57.5
Fuel pressure regulator set at 3.5 psi
"I finally added the regulator this summer and wish I had done it sooner. The engine runs much better and smoother. It is also now more sensitive to tuning changes. Especially the mixture
screw on each carb."
  • 2 years later...
I have a set of Tripple Makunies on my 240Z and not sure what size they are. All I know is when I start the car it runs really rich, the fumes are so bad that my neighbors dog fanted, I mean the dog fell to the ground. When my neighbor took their dog out for a walk, I had just pulled the car out of the garage and started it up to let it warmup, now I know it has always had this problem, so I didn't drive it very much I'm still in the process of getting the framerails done, floorboards and fender wells replace or beefed up for that matter,..... Well anyway as I started up the car about five to 10 minutes had gone by and the neighbor was just passing the back end of my Z and the dog just paused for a minute of two and just fanted. The neighbor said that he could smell the fumes over 20+ yards away. I think my carbs need to be readjusted, what do you think? Long story made short I bought this car from brother in College Station, TX about 7 yrs ago and he did most of the mods to it, but then got married and has started a family and could no longer work on the car so he sold it to me to keep and fix up which I have been doing. My brother mentioned to me that he had bought these Tripple Makunies from a friend in College Station, came off a drag 240Z so he thinks that the jets are too big for the set up that I have. I think so toooo. Could you direct me on what to do? You assistance is greatly appreciated. Joez
