I have my round top carbs & linkage for the '74. Doesn't look like it'll be too difficult to swap the flat tops out (keeping the intake manifold)
In preparation for the swap, I started to drain the rad. Looked for the draincock and couldn't find it. Using a mirror, I located what looks like a brass nut with an allen wrench center where all the diagrams show the drain should be. I'm used to the drains where there's a butterfly-shaped "spigot" that you turn to drain the rad, and all the diagrams I've seen indicate this is what I should find.
Any idea on how to drain this darned thing?
:disappoin
https://www.classiczcars.com/topic/9338-radiator-draining/
You'll probably find a few more "odd" things that a previous owner may or may not have done....:ermm:
I've always replaced the plastic plug with a brass petcock so I never had to worry about the plastic plug twisting off the next time I tried to drain the radiator... pull the brass plug out after you drain it and replace it with a more "modern" drain valve.. Right now I can't think of the right size....
https://www.classiczcars.com/topic/9338-radiator-draining/#findComment-60957
By the way... The spittin image of the original white plastic winged drain plug, with the channel cut into it for a clean draining is for sale, under $5.00 in the "Help" racks of most Auto parts stores. It's marked "Subaru". Both my Z and Roadster are wearing these plugs.
https://www.classiczcars.com/topic/9338-radiator-draining/#findComment-60959
  • 5 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1,027 Guests (See full list)
