Oil Filter Bypass
Has anyone ever split an oil filter after plugging the oil filter bypass in the block? I see a lot of people warn against it, but Iwant to know if anyone has actually done it.
I am planning to plug the bypass in the all new ITS engine I am building since the previous owner didn't plug it and neglected to clean the engine internals properly so the engine ate itself from the inside out. :cry:
Note to all the engine builders, make sure every square millimeter of the engine is spotless before putting anything together.
https://www.classiczcars.com/topic/9415-oil-filter-bypass/
boltmans,
I used to build L-28 GT-2 engines. The by-pass was removed, and the by-pass port pluged. Dry sump systems were used, which produce more pressure and volume than a stock pump. Different types of remote filters were used. None had a problem with blown seals. However, many had tank heaters, and all ran synthetic oil which is thinner and easy to pump when cold.
Its been a while, but I think ITS rules don't allow dry sump sustems. So if you plug the by-pass on a stock system, that stops the oil from completing its circut. The way I see it, you would have to enlarge, and tap the by-pass port for a fitting to run to a remote, non by-pass type filter. Then run the return line back to the center pressure in port of the block filter boss. Would that be ITS legal? Theres a few ITS racers on this site who will hopefully enlighten us. I havn't built one of those in few years, but oil still has to flow out of the block, through the filter & back in again.
Phred
https://www.classiczcars.com/topic/9415-oil-filter-bypass/#findComment-61596
  • Who's Online   3 Members, 0 Anonymous, 1,009 Guests (See full list)
