From 2ManyZs:
Yup, they are different, and I don't think there is any way to modify them to work.... you need to use the center linkage for the 4 screw.
2ManyZs: Are you sure about that? I've got a bunch of 3 screw and 4 screws and I thought the center linkages were all the same. Any differences in the linkages would be between the flat tops and the round tops. The flat tops would have a shorter linkage. seerex did mention that the swap was being done on a 260Z.
https://www.classiczcars.com/topic/9459-center-linkage/#findComment-61965
I have a set of 3 screw round tops in our '73 240Z, and have just completed the swap in our '74 260Z. I purchased the linkage for the '74 from Motorsports and it works great. However, this linkage will not work with the round tops in the '73; I tried it. The difference I noticed was in the metal tab that controls the rear carb; it could also affect the front carb, but once I saw the back wasn't going to fit I didn't pursue it any further. The length of both linkages is the same. I can try to get some digital photos if someone needs them.
https://www.classiczcars.com/topic/9459-center-linkage/#findComment-62026
  • Who's Online   1 Member, 0 Anonymous, 1,483 Guests (See full list)
