moyest Posted January 15, 2004 Share #1 Posted January 15, 2004 Latest problem is that my headers sit too close to the underneath of my carbs & manifold - so the fuel tends to "boil" a bit and performance drops off.Anyone know where I can get my hands on some competition headers for a Z? The ones that drop straight down off the side of the engine, rather than extending out under the carbs?The more clearance I can get between my exhaust and the carbs/manifold, the better!Thanks! Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/ Share on other sites More sharing options...
240Zdragon72 Posted January 15, 2004 Share #2 Posted January 15, 2004 try zcarparts.com (MSA) look in the links under MThey have a 3 to 2 performance header for a good price. Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64366 Share on other sites More sharing options...
kyteler Posted January 15, 2004 Share #3 Posted January 15, 2004 For the price of new headers wouldn't some form of heat coating and a heat shield be a more viable option?I have no idea, I'm wondering myself. Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64367 Share on other sites More sharing options...
240Zdragon72 Posted January 15, 2004 Share #4 Posted January 15, 2004 it would. I did not think of that one. I was in the process of buying a new one for the Lady, and that was on my mind. You could get some heatwrap or if the headers are in good shape, get ahold of Jet-Hot (the link is also on this website under links:stupid: ) maybe that might be a better option. Good lookin out. Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64369 Share on other sites More sharing options...
moyest Posted January 15, 2004 Author Share #5 Posted January 15, 2004 Yup, I thought about coatings for the headers, but they are SO close to the manifold (touching at the front!) that I don't think a coating would do it!? I also wondered about fabricating the headers from scratch, but cost would be around AUS$600 (approx. US$490). I'll check out the MSA site - thanks for the advice guys! Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64370 Share on other sites More sharing options...
kyteler Posted January 15, 2004 Share #6 Posted January 15, 2004 Well, should you get new headers and want to fob off your old manifold touching ones, I may be the kind of fool :stupid: that would buy them, only problem would be freight coupled with how much you'd want for them, judging by your previous response you're in Aus, but at least it wouldn't be as bad a freight price as if they were to come from Japan or Yankeeland.I'm in NZ btw. Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64373 Share on other sites More sharing options...
seerex Posted January 15, 2004 Share #7 Posted January 15, 2004 I looked into the jet hot coating , according to their stats it reduces the heat quite a bit , I don't have a heat issue with the carbs but I wish I had sent it to them before i put it on the car also if you look up chinoz he has a custom heat shield he did that helped alot Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64383 Share on other sites More sharing options...
trs Posted January 15, 2004 Share #8 Posted January 15, 2004 try stewart wilkins motorsport in Sydney. He has a website somewhere but I can't remember the damn link.He sells headers for around $495. Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64415 Share on other sites More sharing options...
symon Posted January 15, 2004 Share #9 Posted January 15, 2004 You could also try ducting cold air onto the exhaust manifold to help keep it cool. I think it is better than wrapping the manifold as if there is excess heat it can warp them. Hope this helps Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64450 Share on other sites More sharing options...
Chino 240Z Posted January 15, 2004 Share #10 Posted January 15, 2004 Heat is a big problem and a bigger problem on a hot summer day! After loosing time and money sitting at the track last summer, I was determined to minimize the heat / carb problem ya know. Here is a pic of the heat sheild I cut from scrap stainless steel and bent it fit under the carbs. I have also installed a piece of duct from the open hole next to radiator support to flow air under the shield too. Now the carbs don't even get warm! I check them after coming in from a 1/2 hour of full throttle, not only is it not hot but makes working & tuning easy- not hot. It may not look original but it works.I have the jet hot on my Formula Firebird car headers and it works too. I will some day get the headers on the Z done too. But heat is not a problem any more. It would be to get rid of the wrapping, and make them last. If you coat something, besure you demand inside besides outside.heat shield.bmp Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64481 Share on other sites More sharing options...
moyest Posted January 15, 2004 Author Share #11 Posted January 15, 2004 Chino, that's one serious heat shield!Regarding the cold air ducting, I was told to simply remove the passenger side floor vent pipe which sits in the corner next to the radiator. It disables the passenger-side floor vent (or if you open it, it poors in HOT air), but the extra air flow helps to keep the engine bay cooler.However, the "cold air" options only help when the car is moving. I think the coating and/or heat shield options are a better solution.I might try coating the headers first, but can you coat slightly rusty headers or do I have to start fresh with nice condition ones?I'll also check out Stewart Wilkins Motorsport - thanks TRS!Cheers Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64509 Share on other sites More sharing options...
Chino 240Z Posted January 16, 2004 Share #12 Posted January 16, 2004 When everything is back in place it's not that serious looking, and you can also now see the duct at the bottom. Yes the car needs to be moving for the duct to help, but then again this car isn't really doing anything else but moving! I don't know about letting in engine compartment air since you get enough exhaust fumes from any car infront and not to mention your own. I know after a long run there is a build up inside and with a helmet on it can be :sick: I was trying several options to cut the heat and it did. Oh and yes you can coat rusty surfaces. That is one of their sales pitches. The jet hot coating makes them look fresh and new besides keeping the heat in the pipe for the heat scavagening benifits. They sent me a demo video before I had it done. I would especially do new ones. Good luck. Link to comment https://www.classiczcars.com/topic/9732-competition-headers-carbs-too-hot/#findComment-64548 Share on other sites More sharing options...
