I know you are asking about 70/71, but on my 72 (mfg in 11/71) I just removed the original motor mounts and the brackets that bolt to the block were the same blue as the engine. The rubber/steel isolators (mounts) were black.
HTH,
Carl
Originally posted by frank13
So, any body know the Name, paint code, maker, or part number for the proper blue for the Zed? :devious:
No, but Les Canaday at Classic Datsun Motorsports had rattle cans of the proper paint color made up. If you check with him, he probably still has them available or could get you the recipe if he no longer has them.
Originally posted by Royce
Both mine were blue same as the engine. I bought my 08/71 240Z from the original owner. Engine had never been out of the car. In fact the car had never been painted.
How did you stop it from rusting then?ROFL
Mike at Banzai Motorworks, 301-420-4200 or zzxdatsun.com has the rattle cans for the Datsun blue paint. I paid $6 a can for an 80% match. The 100% match is $20. BTW, the 80% looks great. I can't see any difference between the can and my block.
All great advice and the only other source for blue engine block paint I may mention would be Tower Paint (towerpaint.com) for rattle cans of PPG and Dupont products. This formula comes from IZCC:
Find a Dupont Dealer and ask them to mix up a quart (5 or more engines) [or spit it in half for a pint] of Dupont "Chroma 1" paint. Be sure and buy the "Chroma 1" catalyst and reducer also.
Tinting guide mix size
806J HS BLACK 177.2
801J HS WHITE 290.0
828J HS FAST BLUE 373.8
830J HS FAST GREEN 444.4
702OG BINDER 844.0
7030G BALANCER 960.4
The color of the engine mount bracket from the sub-supplier was semi-gloss black. It may have been a lacquer or an enamel paint depending on who made the bracket and when. When the engine was built, the mount bracket was bolted on to the side of the block before the block was sprayed. Depending on the mood of the engine builder, the brackets were either sprayed completely blue, oversprayed blue with black showing, or all black and bolted on after the engine was sprayed. None of this was quality controled nice looking. It was all done economically in a minimal amount of time.
Every time I look at an engine with nice cleanly painted parts and shiny aluminum head, I think of the expression "over restored". Of course it looks much better, but it does not replicate how the cars were constructed 30 odd years ago. Blue overspray is on the heater hoses, timing cover, head, water pump, and other major parts.
  • Who's Online   0 Members, 0 Anonymous, 751 Guests (See full list)
