I have purchased an 83 2+2 Turbo w/ 5 speed, complete car and intend to use the F54 block along with my P90 head for a turbo conversion for my 78 280 coupe. I have searched and have read lots of good info but have not found a complete list of what I should strip from my donner car. Is there such a list posted or could some one please list what I should remove from the 82 car? Thank you for your help.....mayolives
https://www.classiczcars.com/forums/topic/9772-turbo-swap-parts-list/
  • 3 weeks later...
I am doing a similar swap. I never found what I would consider to be a complete list (maybe other members have); but, take the engine, all of the engine management(ecm, harness, afm, cruise control(if you want it) You do not need the dash harness unless you are moving the guages as well.
You don't have to take the plumbing, but I would, the radiator, all of its pieces, the oil cooler, all of that was engineered to work with that engine, and can be made to fit in an S30(240, 260,280). If I am too vague still, pm me. I am not too far from you.
Don't forget the rear brakes!
Will
  • 1 month later...
